Fractal Design Integra R2 750W Power Supply Review
Fractal Design appears to have optimized the Integra R2 750W for very high efficiency at low loads, as the power supply displayed amazing (87.2% with 230VAC) efficiency at 20% load for an 80Plus Bronze certified product. However, the efficiency of the power supply diminishes rapidly when it is heavily loaded, forbidding it from achieving a better 80Plus certification.
The Integra R2 750W is not a quiet power supply but it actually performs very well for an 80Plus Bronze certified power supply with such a small chassis and high power output. Noise levels are very low up to 40% load, with the unit being essentially silent. Between 40% and 60% load, the fan is audible but volume levels remain low, comfortable for everyday use. If a load of 400W or greater is placed on the unit, the fan will accelerate quickly, reaching clearly audible levels from a meter away.
The thermal performance of the Integra R2 750W was expected, all things considered. The 80Plus Bronze certified unit has a linear, steady thermal performance, with a temperature delta of 4.5 degrees Celsius at minimum load and 8.4 degrees Celsius at maximum load.
