Thermaltake Introduces the ProWater 850i Water Cooler
The guys over at Thermaltake USA just sent us word that the have announced the ProWater 850i Water Cooler. Notice we didn’t say BigWater as Thermaltake is launching a brand new series of DIY liquid cooling systems, the ProWater Series. The first model to be introduced is the new PW850i that incorporates the latest production techniques and technology of the internal liquid cooling segment. The $149.99 Thermaltake BigWater 760i was a great success as you can see from our review on the unit here, so keep your fingers crossed that the ProWater 850i will perform even better.
The P500 Pump used in the PW850i has a maximum high output of 500L per hour to support the liquid cooling system even under heavy load; the hard-wearing ceramic bearing further increases the life span of the pump, users will not need to worry about pump failure even with extended VGA or memory liquid cooling components. The professionally designed inlet and outlet will eliminate the possibility of air blockages. The PW850i also adopts an automotive style radiator with Thermaltake exclusive “Dimple Dimpled Tubes” DDT technology rather than traditional round tubes, and with the adjustable 120mm fan (1300~2400 RPM); CPU heat will be transmitted efficiently in the coordinated system environment.
