SRS Labs HD Audio Lab Software Review
SRS Labs offers HD audio software for a fully immersive sound experience. The full version of this software is available on their website for $29.99 but navigating to the actual product page you will find it available as a free trial download! Make sure you check out the article and maybe even download the trial to see what this software is all about!
Installing and using HD Audio Lab are really easy and simple to do. Simply download the executable for $29.99 or, for $39.99, you can pop your disk from the retail box into you optical drive, follow the instructions on screen, apply your product code and bang… you are done. HD Audio Lab takes up about 14.5 MB of space on your Hard Drive — fairly small for the huge surprise it packs when it comes to the sound of your audio. Once installed you can click the executable to run the program, and once you do you will be greeted with the user interface. When run for the first time the .exe will open and turn on HD Audio Lab for you.
