NZXT Introduces HALE82 V2 Power Supply w/ White PCB
The NZXT HALE82 V2 Power supply series was released today. Designed for mainstream users and enthusiasts alike, the HALE82 V2 is a fully modular power supply with 80 Plus Bronze certification. In addition to its fully modular design, the HALE82 V2 PCB features an intelligent component layout that leaves room for optimum airflow, allowing its 135mm fan to run silently and effectively. The HALE82 V2 will be available soon for just $79.99 (550W) and $99.99 (700W). HALE82 V2 is confirmed compatible with Intel’s 4th generation Core processors formerly codenamed Haswell. It also features a white PCB, which is cool, but you can’t really see it!
HALE82 V2 Features
- 80 Plus Bronze Certification (HALE82 V2 only) ensures efficiency levels up to 85%
- Completely modular design with labeled back plate for easy installation and clean look
- NZXT design element infused on the exterior/interior power supply with worlds first Innovative white and black PCB design for better isolation and identification
- IFCT: The intelligent fan control technology is designed for better thermal solution
- Strong single +12V rail that provides stability and ease of use with the ability to deliver clean currents under a heavy load
- SLI and CrossFire Ready
- 135mm silent fan for smooth, silent rotation, and optimal air intake
- Wide Input Range (HALE82 V2S only): AC main is from 160V to 280V for emergency countries.
- Active PFCFull protections for over voltage, current, power, under voltage, and short circuit protection
- Safety Approvals for: CE / FCC / CB / TUV / cTUVus / CCC
- Backed by a 3 Year Manufacturers Warranty
- Standard: Comply ATX 12V V2.31 and EPS 12V V2.92
