Lian Li launches PC-XB01 – Xbox 360 Chassis Replacement
Lian-Li is launching the PC-XB01 chassis for the Xbox 360 today. The XB01 is a chassis replacement for the XBox 360 chassis, which alleviates heating issues from hot components and reduces noise from vibrating optical drives in the original case design. The PC-XB01 requires DIY knowledge for the transfer of components, but once completed, heat will no longer be a factor in dampening your XBox 360 gaming experience. The Manufacturers Recommended Selling Price (MSRP) is set at $149USD and it is expected to be for sale later this month.
The Lian Li PC-XB01 is the perfect complement to the Xbox 360 to alleviate heating issues. The stylish exterior gives your product a sense of class and will fit in with almost any living room environment. Microsoft Inc is very strict on warranties, so it should be noted that you will not be able to return your product if you use the Lian Li PC-XB01 alternative. With that being said, you are less likely to have overheating.
