Lian Li Launches PC-TU100 Mini-ITX Briefcase Chassis – Lan Gaming 007 Bond Style
ian-Li has announced their latest edition to the briefcase chassis “TU” series – PC-TU100 Mini-ITX Chassis. The dimensions on this small case are 158 x 275 x 242mm (WxHxD) (6.2” x 10.8” x 9.5”) and a weight of 1.77kg (3.9lb). This makes it more compact than the PC-TU200. Lian Li hopes that the fully aluminum PC-TU100 will become the ideal choice for LAN gaming rig with its top-mounted handle and its support for the latest powerful low profile graphics card. It is styled to be a retro “007-esque” chassis.
Two 2.5” hard drives or SSDs can be mounted on the bottom drive rack. An additional 2.5” drive can be placed in the slim optical drive bay, if no optical drive is installed. Graphics cards up to 190mm can be installed in the chassis – enough room for some of the latest small form factor graphics cards. The PC-TU100 supports SFX power supplies up to 170mm. The PC-TU100 will be available in silver and black at the end of June for the suggested retail price of US$109.99.
