GlacialTech Launches CPU Cooler F101 Silent and PWM
GlacialTech launched their latest CPU Cooler F101 which can support for Intel Core i7/i5 Processors on LGA775/1156/1366 and even AMD socket AM2 & AM3 platforms. The unique design incorporates a specially aligned sinter heat-pipe (combination of five pipes) that dissipates the heat from the CPU directly into the heatsink fins. From there, the Silent version’s fan quietly and efficiently brings the temperature down. The CPU cooler comes with a 120 mm fan, which offers a unique shape, as part of the cooler hovers over the chipset.
GlacialTech CPU Cooler F101
GlacialTech has implemented a cost effective and useful way to keep your processor cool. When running resource hungry applications and you have the PWM version installed, turn up the RPM to manage your heat dissipation more effectively. While the PC is idle or doing non-intensive work, turn the RPM back to its own position. This is how you manage your power consumption, generating lower decibel of noise and gives you a peace of mind. Alternatively, the users have the option to purchase the Silent version as GlacialTech offers you the variety and options to suit your needs.
