Fractal Design Launches Window Side Panel for Define R3 PC Case
Fractal Design announced this morning that the company will begin selling a windowed side panel for the Define R3 PC case in August 2012. The new side panel features a large fully transparent window allowing you to display your setup in style. The acrylic window side panel features the same clean, Scandinavian design as the case itself, and has a completely flat outer surface without any plastic bezel or rivets. Installing the Fractal Design side panel could not be easier – simply remove and replace the standard panel! The side panel will be available in both Pearl Black and Arctic White for $19.99 or 18,90. Not a bad price considering you get a whole new panel, but we have a feeling this one isn’t going to be bullet proof.
Define R3 Window Side Panel Key Features:
- Completely flat outer surface, no plastic bezel and no visible rivets
- Clean, stylish Scandinavian design that matches the case
- Easy installation -simply replace the standard panel, no modification necessary
- Window size (W x H): 270 x 290 mm, positioned 45mm from both the top and the back edge
- Available in Pearl Black and Arctic White
