Corsair Power Supply Survey – Make a Difference!
Corsair is conducting a power supply survey to try and figure out what people are looking for in when buying a power supply these days. They ask you ten questions to see if they can figure out what consumers are wanting in their next power supply. The survey is pretty technical as they ask the importance of things like low ripple/electrical noise and 50C operating temperature ratings.
The Corsair HX1000W features six PCI-Express connectors, both 6-pin and 8-pin compatible, to power multiple high-end graphics cards and two EPS12V connectors for dual CPU configurations. The truly independent dual transformer, dual rail design allow for optimum load balancing resulting in greater performance and stability. Industrial-grade 105C primary, secondary and solid state capacitors provide up to four times the lifespan of traditional components.
