CoolIT Systems Announces Workstation Water Cooler Called Aero
CoolIT Systems announces the new Workstation Cooler, a CPU liquid cooling device utilizing CoolITs patented, award-winning MTEC technology. With this device, small/medium businesses, video production/pro audio studios, game developers, government offices, and churches can maximize the performance from their workstation PC. Because workstations and servers typically require power-intensive software applications, the CPU and other internal computing hardware are placed under a heavy load which can in some cases, cause the entire system to overheat or fail.
CoolIT Systems Work Station Solution is based around the Aero CPU Cooler. The Aero is a CoolIT Systems Inc. patented product that removes heat from individual components and transfers the heat outside the computer case.It combines facets of air-cooling and liquid chilling through purpose-designed internally installed components. It can aggressively remove heat from a computer quietly, efficiently, and reliably. This system alleviates any risk of condensation, is highly effective, and is easy to install.
