Cooler Master Announces Hyper 612S and 612 PWM CPU Coolers
Cooler Master announced the Hyper 612 CPU Cooler series today, but these coolers have a twist. The Hyper 612S is available only in Europe and the Hyper 612 PWM is only available in North America. Both versions feature the same 806g heat sink that uses six heat pipes as the only real difference is in the 120mm cooling fan and the color of the top of the cooler. The Hyper 612S features a silver top plate and has a low noise 120mm 3-pin fan that pushes 52.6 CFM at 22.5 dBA. The Hyper 612 PWM features a black top plate and has a more powerful 120mm 4-pin PWM fan that pushes 82.9 CFM at 36.0 dBA. The Hyper 612 PWM is shown below.
The Hyper 612 series CPU coolers are designed for optimum heat dissipation at low fan speeds thanks to wider fin gaps, a special fin blade design, and a precise Heat pipe layout that has all 6 Heat pipes crossing the CPUs hot spots. This special Heat pipe layout turns them into 12 virtual Heat pipes with direct contact to the hottest parts of the processor. For ease of installation and cleaning the Heat sink features a snap-on fan-bracket, which lets you replace or remove the fan to brush dust out of the Heat sink within seconds.
