Cooler Master Announces Hyper 612 PWM CPU Cooler at $49.99
Cooler Master has officially announced the Hyper 612 PWM CPU Cooler in North America. Cooler Master says this cooler strikes a balance between good cooling performance and decent noise levels. they also go on to say that the Hyper 612 PWM outperforms all-in-one liquid coolers and high-priced counterparts alike while maintaining minimal noise levels. The Hyper 612 PWM features a black top plate and has a more powerful 120mm 4-pin PWM fan that pushes 82.9 CFM at 36.0 dBA. The retail price is $49.99 and the CM Hyper 612 PWM is shown below.
The Hyper 612 PWM CPU Cooler is designed for optimum heat dissipation at low fan speeds thanks to wider fin gaps, a PWM fan with a special fin blade design, and a precise heat pipe layout that directs each of its six heat pipes across CPU “hot zones”. Employing this unique heat pipe layout allows the heat pipes to multiply into twelve virtual heat pipes that cool the hottest parts of the processor.
