Cooler Master Announces $50 Mini ITX Case Called Elite 120 Advanced
Cooler Master today announced the all new Elite 120 Advanced PC case. The Elite 120 Advanced answers the call for an elegant mini-ITX size chassis that supports a wide variety of hardware. It can accommodate even the largest Ultra High-End VGAs, a 5.25 optical drive, up to 5 HDDs or SSDs and a standard sized power supply. Thanks to a smart airflow system featuring 3 fans it manages to still keep the system cool and quiet. The CM Elite 120 Advances is topped off with a stylish brushed aluminum front with USB 3.0 ports along with the usual buttons you’d expect. The Elite 120 Advanced is available now and has an MSRP of $49.99. You can find out more about it on this product page.
CM Elite 120 Advanced Case Features:
- Unprecedented airflow for a Mini-ITX case
- 1/3 the size of a standard case
- Supports standard length ATX PSUs with innovative rear mount
- Supports Ultra High-End VGAs (HD7990/GTX690)
- Stylish Aluminum front panel
- USB 3.0 Super Speed Support
- Features a Full Size 5.25 Drive Bay
- Supports Up to 3 x 3.5 / 4 x 2.5 HDD/SSD (converted from 2 x 3.5″ HDD bay)
Offering no compromises, Elite 120 Advanced is marked as the benchmark for a brilliant internal layout. Feel confident with a long 13 of graphics card space supporting virtually all of the longest graphics cards. An easy to use rear PSU bracket, adapted from the Cosmos 2, allows Elite 120 Advanced owners to easily install long power supplies. Three 3.5 hard drives bays and a 5.25 optical bay round out its full system support. Elite 120 Advanced also offers best in class cooling including a 120mm front intake, 80mm slim side fan, and additional support for a hard drive mounted 120mm fan. Highly compatible with components, spacious and elegant, the Elite 120 Advanced also maintains Cooler Masters reputation for value.
