Thermaltake Launches Riing 12 and 14 LED Radiator Fan Series
Thermaltake Riing 12 and 14 LED Radiator Fan
Full Series High-Static Pressure with Patented LED Ring Now in 6 Colors: Yellow�Orange� Red�Blue�Green�White
Taipei, Taiwan�August 10, 2015�Thermaltake, an industry leader in computer chassis, thermal solutions, and power supply units, has launched the new Riing 12 and 14 LED Radiator Fan Full Series, 120mm and 140mm fans fitted to enhance static pressure, producing impressive cooling performance with an optimized fan blade. Hydraulic bearings for silent operation guarantee ultra-low noise. In addition, an anti-vibration mounting system strengthens the stability during operation. The patented LED Ring maintains color and brightness uniformity. The LED ring is available in yellow, orange, red, green, blue, and white, a palette of 6 colors to style up your chassis.
Thermaltake Riing 12 Yellow
More details about Riing 12 and 14 LED Radiator Fan Full Series:
Wind Blocker Frame
The wind blocker frame is designed to work with the Concentrated Compression Blades (CCB) pressure mechanism by directing airflow towards the middle section of the blade, thereby creating a compression effect and blocking any pressure from escaping. This reduces the blades noise and vibration, creating a perfect balance between power and sound.
Custom designed for high-static pressure requirements of demanding applications such as radiators, the Concentrated Compression Blade (CCB) is engineered to focus the inner weaker circle of air outwards, allowing the outer section to pressurize and compress the air.
Hydraulic Beairng with Low-Noise Design
The hydraulic bearing self-lubricates with a high quality, friction-reducing substance which lowers operating noise and improves efficiency. The seal cap prevents leakage of the lubricant, and improves the lifespan of the unit. The LNC (Low-Noise Cable) can reduce the noise level by 23% in average.
Anti-vibration Mounting System
In-mold injection anti-vibration rubber pads provide hassle-free usage for 80% protection coverage, including all four corners.
Multiple Colors of the Patented LED Versions Available
Riing Fan Series is available in 6 different LED versions (yellow, orange, red, blue, green, and white), adding cooling aesthetics to the chassis.
For more details on the Thermaltake Riing 12 and 14 LED Radiator Fan Full Series please visit: http://www.thermaltake.com/cooler.aspx
