ID-COOLING HUNTER DUET – AIO Water Cooler For CPU and GPU
ID-COOLING Releases HUNTER DUET Integrated AIO Water Cooler
  • One Radiator & Dual Pump Design for CPU & GPU
July. 20, 2015 ID-COOLING officially releases the worlds first integrated AIO water cooler for CPU & GPU with one radiator two pumps design, named HUNTER DUET. Along with this cooler, ID-COOLING is going to launch a full product line of water cooling under FROSTFLOW series.
HUNTER DUET is equipped with a 240mm radiator mounted with a pair of SF-12025 high static pressure fans. Fan speed is PWM controlled from 800 to 2000RPM, pushing max. airflow of 84.5CFM each. On four corners are mounted with rubber dampeners to absorb operating vibration.
The pumps are designed with comet-tail LED lighting on the top. Bearing type is Ceramic bearing and the pump speed is set at 2500RPM. Copper base contacts CPU/GPU to help the heat transfer. Micro fin submerged design increases the heat dissipation surface. The dimension of the whole water block is 6536mm.
EPDM Rubber tubes connected water blocks and radiator together. From CPU water block to GPU block, tube length is 250mm; GPU to radiator, 380mm; radiator to CPU, 250mm. Inside tubes is self-contained highly efficient and eco-friendly liquid coolant.
Universal mounting brackets are included. HUNTER DUET is compatible with (CPU) Intel LGA2011/1366/1150/1155/1156/775 & AMD FM2+/FM2/FM1/AM3(+)/AM2(+). For GPU, the mounting kit supports mounting holes 58.4*58.4mm; 53.3*53.3mm; 51*61mm.
The MSRP for HUNTER DUET is $139.99.
For more product information, you can check http://www.idcooling.com. Youre also invited to like ID-COOLING on Facebook: www.facebook.com/idcooling.global.
