EK Water Blocks Announces Water Block For Galaxy / KFA GTX 780 Ti Hall Of Fame Video Card
EK-FC780 GTX HOF for Galaxy / KFA GTX 780 (Ti) Hall Of Fame released
EK Water Blocks, Ljubljana based premium water cooling gear manufacturer, is proud to introduce the EK-FC780 GTX HOF – a full-cover water cooling solution for the Galaxy / KFA NVIDIA GeForce GTX 780 (Ti) Hall Of Fame series graphics card.
EK-FC780 GTX HOF water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it’s VRM to remain stable under high overclocks. EK-FC780 GTX HOF water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of nickel-plated electrolytic copper while the top is made of quality white POM Acetal. For a perfect visual match nickel-plated screws and white FC Terminal are used to perfectly mimic the colour scheme used by this extraordinary graphics card. Screw-in brass standoffs are pre-installed and allow for safe installation procedure.
Up to four EK-FC780 GTX HOF series water blocks can be interconnected with EK-FC Terminal or EK-HD Tube & Adapter System which allows for hassle-free piping job. The product is available in a single variant:
SKU
MSRP (incl. VAT)
EK-FC780 GTX HOF – White Acetal+Nickel 102,95
