Kingston Launches World’s First Low-Voltage DDR3 Memory Kit – 1.25V at 1600MHz
Kingston Technology today announced the release of the world’s first ultra-low voltage memory running at 1.25 volts at 1600MHz. The new offering is part of the new Kingston ‘LoVo’ (low voltage) HyperX DDR3 High-Performance memory product line. The dual-channel kit (Kingston part #: KHX1866C9D3LK2/4GX) comes pre-programmed with two XMP-ready profiles: 1.25 volts at 1600MHz and 1.35 volts at 1866MHz. The latter profile is also a world’s first for speed matching higher frequency with a lower voltage.
“Kingston is proud to lead the charge with memory for the new generation of energy efficient systems that yield higher performance,” said Mark Tekunoff, senior technology manager, Kingston. “Energy-conscious consumers need to look no further for memory than the HyperX ‘LoVo’ line when they are assembling the components needed to achieve better PC power performance.”
