Gelid Ships Sleeved Power Supply Cables
Thermal Solutions specialist GELID Solutions adds Cable as a new product category to its GAMER product line. To start power supply cable adapter GELID is launching 6pin (PCI-E), 8pin (EPS) and 24pin (EPS) cables. They are each prepared with a high-end UV reactive single sleeve in your choice of black, white, red or blue. All cables have a AWG 18 size and a length of 30cm. When it comes to pricing the 6 Pin is $6, the 8 Pin is $8 and the 24 Pin is $10.
“When quality and color can add value to your system, you will start to appreciate them,” said VC Tran Marketing Director of GELID Solutions Ltd.
