Cooler Master Launches Notepal A200 Laptop Cooling Stand For $40
Are you looking for a new laptop cooler? Cooler Master today announced the Notepal A200 laptop cooling stand for notebooks that have a screen size of up to 16″. The A200 has two large 140mm fans for optimized airflow and a perforated aluminum cooling surface that helps siphon heat from your laptop. A built-in control for the fan lets you adjust performance to obtain the perfect balance between fan speed and noise levels. The MSRP on the CM Notepal A200 laptop cooling stand has an MSRP of $39.99.
Cooler Master Notepal A200 Laptop Cooling Stand Specifications
- Model – R9-NBC-A2HS-GP
- Color – Silver
- Material – Aluminum, Plastic
- Weight – 0.69 kg / 1.5 lbs
- Dimension – 367mm x 262mm x 24.5~60mm (14.4 x 10.3 x 0.9~2.4 inch)
- Fan Dimension – 140×15 mm * 2
- Fan Speed – 700~1200 RPM15%
- Fan Noise Level (dB-A) – 20~28 dBA
- Fan Airflow – 92 CFM
- Power – USB 5V DC
- USB – USB 2.0/1.1*2 + mini USB*1
- Compatibility – Supports up to 16 laptops
- Warranty – 1 year
