Callpod Chargepod 6-way Charging Device Review
Chargepod is a 6-way charging device that allows you to charge multiple cell phones, PDAs, headsets, and most other mobile electronics with a single power cord. Chargepod uses voltage regulator technology and interchangeable power adapters to safely charge all of your mobile devices regardless of manufacturer or model.
The Chargepod worked like a charm and reduced all of the cables we had around the office down to just one. The only downside to the Chargepod would be price, but when you think about it most families have thousands of dollars worth of electronics. Spending $39.99 on the Callpod Chargepod Value Pack and then $9.95 for extra cables isn’t really that big of a price to pay for the convenience that offers. Not only that, but it might also reduce the chances of you getting hurt from tripping over all those charger cables you have in your house.
Print
